Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product Pneu0400png 00000003129
Rotary vane pumps
June 2, 2005
Series QR rotary pumps meet high-flow, pulse-free vacuum or pressure needs. Oil-less pump design has cast-iron pump housing, permanently lubricated ball-bearing motors with built-in inlet and exhaust filters for clean flow. Single-or three-phase ...
Series QR rotary pumps meet high-flow, pulse-free vacuum or pressure needs. Oil-less pump design has cast-iron pump housing, permanently lubricated ball-bearing motors with built-in inlet and exhaust filters for clean flow. Single-or three-phase ac motors. Provides up to 10 psi continuous pressure or 15 psi intermittent. Maximum rated vacuum is 26 in.-Hg. Maximum flow is 10 cfm.
Rietschle Thomas Sheboygan Inc.,
(920) 457-4891,
www.rtpumps.com
