Two-piece modular P3000 series pump drives transmit up to 500-hp input to two or three pump outputs sized for SAE A through SAE D. Ground gears and bearing system are rated for speeds to 3500 rpm. Stiebel Drive Technology Inc. (864) ...
Two-piece modular P3000 series pump drives transmit up to 500-hp input to two or three pump outputs sized for SAE A through SAE D. Ground gears and bearing system are rated for speeds to 3500 rpm. Stiebel Drive Technology Inc. (864) 373-9442 www.stiebel-drives.com
