Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads 2012 02 Parker 877 Series Pto
Power takeoff
Feb. 14, 2012
Chelsea 877 series PTO features a compact housing that provides generous clearance. Two assembly arrangements maximize installation possibilities. High capacity bearings and gear designs provide torque ratings to 670 lb-ft. It offers a 10-bolt mounting pattern that will fit on most automatic transmissions. One hose is required for a simplified installation. Eight internal gear ratios are rated for a variety of speeds.
10-bolt mounting pattern that will fit on most automatic transmissions. One hose is required for a simplified installation. Eight internal gear ratios are rated for a variety of speeds. Direct mount pump flange options are available with Wet Spline design that provides increased PTO and pump shaft life. It accommodates 2- and 4-bolt mounting patterns.
Parker Hannifin Corp., Chelsea Product Div., (662)-895-1011, www.parker.com
