PTO with vane pump
June 11, 2013
PTO and vane pump combination based on the Parker T6C family. Interchangeable vane cartridges provide flow rates from 3.4 gpm (12.9 lpm) to 31.7 gpm (119.9 lpm) at 1200 rpm and pressure ranges to 3500 psi (240 bars). Design provides quiet operation. Clutch pack provides single continuous duty torque rating of 335 lb-ft. (454 N-m). Parker Hannifin Corp., Chelsea Products Div.
662.895.1011, www.parker.com/chelsea
