Genie S-40 and S-45 use hydraulics for virtually all working functions. A hydrostatic drive provides hydraulic power to four wheel motors, each of which drives a triangular track drive. A pair of hydraulic cylinders provides front-axle steering, and a second pair pivots the rear axle to keep it in contact with the ground.
Powerful, yet gentle
Furthermore, both machines also use Terex’s active oscillating axles, which use a pair of hydraulic cylinders to keep tracks in contact with the ground on uneven and undulating surfaces within the stroke limit of the cylinders. This feature ensures that the vehicles maintain maximum traction, power, and torque.
Frank Schneider, Senior Product Manager, Terex Aerial Work Platforms, explained, “The four-point track system allows the tracks to drive softer over sensitive surfaces while also reducing the platform movement. This is a superior product for specific geographies, such as the Southern United States and Northern Europe, where soil and site conditions require specialized pieces of equipment.”
Because the tracks are encased in rubber, they do less damage to sensitive ground surfaces, such as turf, while still remaining rigid. Reduced ground pressure provides a high level of flotation in terrains such as sand, mud, and compact snow.
Attention to detail
The Genie Trax booms offer traditional front wheel steering, with a 30° steer angle. By driving and steering like a wheeled machine, each triangular shaped track can swivel 22° up and down to easily follow undulating terrain and sharp changes in slope, such as the break-over angle found on many transport trailers. Furthermore, their narrow chassis and front wheel steering allow the Trax booms to fit into narrow locations and tight job sites with ease.
The Trax booms share a common chassis with the standard wheeled Genie S-40 and S-45 machines, resulting in service parts commonality. The common platform also limits the amount of service training for technicians who work on both types of machines. With a maximum drive speed of 2.5 mph, units are able to get around job sites quickly.
High-quality hydraulics
According to Mike Kehler, P. E., Engineering Manager, Boom Engineering, Aerial Work Platforms, at Terex’s Moses Lake, Wash. facility, propulsion for both models is provided by a hydrostatic drive provided by Sauer-Danfoss. A hydraulic motor drives each track through a wheel drive.
The machines also use two gear pumps for other functions. A 2-gpm gear pump powers the oscillation system, and a 7-gpm gear pump provides boom functions and steering, with priority flow for steering. A steer axle is equipped with two cylinders and a tie rod between the two yokes to provide steering.
