This air-actuated PTO clutch saves energy by transmitting power to the hydraulic pump only when needed, which also reduces wear and tear on the pump. Hansen Marine specifies PTO 250 clutches from Logan Clutch Corp., Cleveland, for this application. The heavy-duty PTO 250's compact, in-line configuration suits the power train well, as does its high torque rating. Because the clutch is air-actuated, mechanical linkages are eliminated, and the bow thruster can be rapidly engaged or disengaged remotely from the vessel's control station.
Logan's PTO 250 clutches incorporate a multiple disc pack design, enabling them to transmit high torque within a compact housing. They are corrosion resistant, require no external lubrication, and are self-adjusting. Unlike springs, the compressed-air actuation selfcompensates for wear to provide consistent performance.
For more information on Logan clutches for mobile and industrial applications, call Logan Clutch at (800) 525-8824 or visit www.loganclutch.com.
