PVWJ open-loop, axial-piston pump offers stability in low- to medium-horsepower industrial and mobile hydraulic applications. It is available in three frame sizes and ten displacements, ranging from 0.66 to 7.94 in.3/rev. It is rated for ...
It is available in three frame sizes and ten displacements, ranging from 0.66 to 7.94 in.3/rev. It is rated for continuous pressure from 1500 to 5000 psi, and maximum pressures from 2800 to 5800 psi. Flow rates range from 4.2 to 58.2 gpm at 1800 rpm, rated continuous pressure, and 14.7 psia.
