Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads 2012 04 Sunsource Eps
Hydraulic power units
April 9, 2012
Engineered Power System (EPS) program allows for quick and easy customization of hydraulic power units. Basic platforms include flows to 30 gpm and pressures to 3000 psi, with horizontal or vertical pump-motor mounts.
Engineered Power System (EPS) program allows for quick and easy customization of hydraulic power units. Basic platforms include flows to 30 gpm and pressures to 3000 psi, with horizontal or vertical pump-motor mounts. They are available with a fixed or variable-displacement pump, D03 and D05 valves, modular stacking, and water or air-cooled heat exchanger. Silver, Gold or Platinum packages allow advanced customization with each series.
SunSource, (888) 786-7723, www.sun-source.com
