Variable-Speed Pump Drive
Oct. 10, 2014
​Sytronix SVP 7010 variable speed pump drive offers a performance range up to 120 kW. It uses pre-programmed features to provide high control accuracy
Sytronix SVP 7010 variable speed pump drive offers a performance range up to 120 kW. It uses pre-programmed features to provide high control accuracy and dynamics. Direct-coupled motor-pump assembly reduces overall length 20% and reduces drive inertia 50%. Can be used in open and closed loop hydraulic circuits. Pumps with 2 or 4 quadrant operations are available with 3 levels of performance. Provides energy savings through pump speed reduction during idle and partial load operation. Plus, noise reduction up to 20dBA.
Bosch Rexroth, (800) 739-7684
