The Tech-Roll is a conveyor pulley driven by a hydraulic motor inside it. The design not only saves space and weight, but simplifies installation and reduces maintenance.Conditions are even worse with conveyors driven by electric motors. An electric motor of equal power rating is several times the size and weight of a hydraulic motor. Plus, an electric motor needs a gearbox to convert its high-speed rotation to the speed of the conveyor. The gearbox adds even more size and weight to the conveyor. Then, of course, electrical lines feeding the motor, and the motor itself, pose a potential risk from electric shock.
No shell game
To engineers at Tech-Roll Inc., Blaine, Wash., it just made sense to put the hydraulic motor inside the conveyor drive pulley. Doing so takes advantage of otherwise unused space inside the pulley and protects the motor from the elements and physical damage. This is especially important for conveyors used in food processing applications, where components must be shielded from caustic washdown solution. The pulley also acts as an enclosure to prevent any incidental fluid leaks from contaminating conveyed products or dripping on the floor. As a precaution, the Tech-Roll comes with a small drain hose to route any incidental leaking fluid away from sensitive areas.
As with any hydraulic motor, the pulley can operate in wet atmospheres where electrical power would pose a hazard. The motor also produces full torque at startup and at all drive speeds. Speed can be easily controlled using standard hydraulic valves.
The Tech-Roll consists of two main parts: a cylindrical shell and a modified hydraulic motor. The shell is closed at one end and fitted with a pillow block bearing. The other end is open and has the hydraulic motor rigidly mounted to a shaft and an end plate with a bearing assembly. The end plate turns around the shaft. The motor is inserted into the open end of the shell, and the motor’s splined shaft fits into a fixed flange inside the shell. The end plate with the bearing assembly closes the open end of the shell.
