Radial-Piston Motors
Jan. 20, 2012
YSC series radial piston motors resist cavitation and accommodate freewheeling at high speed and continuous operation. Featuring a compact design, they come in displacements of 40 to 988 cc/rev, with maximum continuous speeds from 300 to 1200 rpm. They are rated for maximum continuous pressure to 250 bar and transmit theoretical torque from 0.62 to 15.70 Nm/bar.
YSC series radial-piston motors resist cavitation and accommodate freewheeling at high speed and continuous operation. Featuring a compact design, they come in displacements of 40 to 988 cc/rev, with maximum continuous speeds from 300 to 1200 rpm. They are rated for maximum continuous pressure to 250 bar and transmit theoretical torque from 0.62 to 15.70 Nm/bar.
Young Powertech, (888) 465-3561
www.youngpowertech.com
