Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 12 01 2010 86698 Radialpist 00000059300
Radial-piston motors
Dec. 14, 2010
YITM series piston motors come with a roller bearing between the piston and crank, providing high torque efficiency and smooth operation. Hydraulically balanced distributor provides high volumetric efficiency. It is available in 16 frames and ...
YITM series piston motors come with a roller bearing between the piston and crank, providing high torque efficiency and smooth operation. Hydraulically balanced distributor provides high volumetric efficiency. It is available in 16 frames and 59 displacements, from 3.9 to 978 in.3/rev. Torques range from 189 to 46,429 N-m and speeds range from 0.3 to 900 rpm.
Young Powertech Inc., (888) 465-3561
www.youngpowertech.com
