Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 06 01 2010 85879 Directiona 00000058529
Directional control valve
June 11, 2010
Salami monoblock VDM6A is a compact directional control valve that features up to seven working spools as well as load check valve protection on each section. It can be equipped with auxiliary valves on each working port. It offers nominal flow of 12 ...
Salami monoblock VDM6A is a compact directional control valve that features up to seven working spools as well as load check valve protection on each section. It can be equipped with auxiliary valves on each working port. It offers nominal flow of 12 gpm and maximum flow of 16 gpm, and is rated for maximum pressures to 5400 psi. Available sizes include SAE 6, SAE 8, and T line SAE 10.
Salami Fluid Power, (514) 602-8006, www.salami.it
