Edited by Mary C. Gannon CLK pressure-control valve has an added safety function that provides operational ease in hydraulic systems where temperature increases and/or external load peaks can cause problems. When closed, the seated valve is ...
CLK pressure-control valve has an added safety function that provides operational ease in hydraulic systems where temperature increases and/or external load peaks can cause problems. When closed, the seated valve is leak-free, eliminating need for additional check valves or continuous refeeding. It offers 5.8-gpm flow at 380 bar with a maximum pressure of 500 bar.
