Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 13518 Products06 00000006533
Cartridge relief valve
Feb. 27, 2006
Hot oil shuttle with relief valve fits into size 10 cavities. Springless valve is available with builtin relief setting of 100 to 400 psi and flow rating of 6 gpm at operating pressure of 5000 psi. Uni-body design and oversized seating allow ...
Hot oil shuttle with relief valve fits into size 10 cavities. Springless valve is available with builtin relief setting of 100 to 400 psi and flow rating of 6 gpm at operating pressure of 5000 psi. Uni-body design and oversized seating allow high-torque tightening during installation, reducing need for locking mechanisms or lock wires. Internal pilots at port 1 or 2 allows flow to tank to remove oil from low pressure side for cooling or filtration. It is available with 3/8-in. BSPP or #6 SAE tank port.
Command Controls Corp., (847) 429-0700, www.commandcontrols.com
