Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 07 01 2010 86038 Miniaturen 00000058653
Miniature needle valve
July 14, 2010
Edited By Mary C. Gannon MNV-1010-303 miniature, motor controlled needle valve provides precise flow or pressure control in limited space. It operates with inlet pressure to 500 psi and remains stable during temperature fluctuations. It is normally ...
MNV-1010-303 miniature, motor controlled needle valve provides precise flow or pressure control in limited space. It operates with inlet pressure to 500 psi and remains stable during temperature fluctuations. It is normally constructed of 303 stainless steel but is also available in 316 stainless steel. It offers on-off modulating operation, and comes with 10-32 threaded ports.
Beswick Engineering, (800) 354-5014, www.beswick.com
28962100 © Dmitry Kalinovsky | Dreamstime.com
Creating systems for safe machine operation is critical for fluid power and machine manufacturers
