Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 03 01 2008 79454valvedrive 00000052045
Valve driver
March 26, 2008
The 24P valve driver provides a simple PWM open-loop voltage controlled, 2.5 A output in direct response to front panel knob. It operates on 10-32 Vdc power with four trim pots to adjust PWM frequency, minimum and maximum output, and 0-5 ...
The 24P valve driver provides a simple PWM open-loop voltage controlled, 2.5 A output in direct response to front panel knob. It operates on 10-32 Vdc power with four trim pots to adjust PWM frequency, minimum and maximum output, and 0-5 sec ramp. It is fused at 5 A with an indicator and suits applications where the variable PWM output can provide a direct drive for hydraulic flow control. Options include remote panel pot, PLC control 1-6 V or 4-20 mA.
Ditco Inc., (253) 854-1002, www.ditco.net
