Model FC (with mechanical microswitch) and FI (with inductive proximity switch) valves provide electrical output to indicate position of in
ternal spool or poppet, thus revealing hydraulic status. Conforming to Machine directive 2006/42/CE, the feature is available with direct or pilot operated subplate or cartridge mounted valves. The feature verifies that the valve has shut off fluid energy to one or more actuators.
Atos Systems Inc., (519)465-3063, www.atos.com
