Changeover valve
Oct. 9, 2012
Series USV08 and USV16 changeover valve for hydraulic traction drives enables the driver to change over from a series circuit such as “travel gear” to a parallel circuit with differential-lock valve. They are rated for maximum operating pressure of 320 and 420 bar, and nominal flow rates of 120 and 160 lpm, respectively. They operate in temperatures from –20° to 80°C and feature Nitrile Butadiene rubber seals.
Bucher Hydraulics GmbH, +49 7742 852 178, bit.ly/hp1012bucher
