Explosion-proof valves
Dec. 12, 2012
Stainless-steel electrohydraulic valves feature corrosion-resistant external and internal parts to withstand extreme and corrosive environments and ensure compatibility with water-based fluids and pure water.
Stainless-steel electrohydraulic valves feature corrosion-resistant external and internal parts to withstand extreme and corrosive environments and ensure compatibility with water-based fluids and pure water. Leak-free poppet style or spool type; direct or pilot operated; on-off or proportional solenoids with standard manual override or optional manual reset, they are available with standard 10 W or low consumption 3.5 W power supply. They are rated for flows from 10 to 220 lpm and maximum pressure from 250 to 350 bar.
Atos, (519) 465-3063, bit.ly/hp1212atos
Flow-Control Valves Regulate Speed
June 12, 2019
Flow-control valves include simple orifices and sophisticated closed-loop electrohydraulic valves that automatically adjust to variations in pressure and temperature.
Open-Loop Proportional Valves
June 28, 2019
All-purpose ZE proportional valves for open loop electrohydraulic systems feature a cURus certified threaded solenoid.
