Solenoid valve
Jan. 14, 2013
Series 7 direct-acting, solenoid valve is designed with a coil that accommodates fluid pressures to 1200 psi in a 2-way NC configuration. It is available in 2- and 3-way operation, features 13⁄16 and 15⁄8-in. body sizes machined from aluminum or brass with 1⁄8 or 1⁄4 in. NPT ports, orifice sizes from 3⁄64 to 1⁄4 in. and draws 11, 12 or 14 W of power from either ac or dc power.
Series 7 direct-acting, solenoid valve is designed with a coil that accommodates fluid pressures to 1200 psi in a 2-way NC configuration. It is available in 2- and 3-way operation, features 13⁄16 and 1 5⁄8-in. body sizes machined from aluminum or brass with 1⁄8 or 1⁄4 in. NPT ports, orifice sizes from 3⁄64 to 1⁄4 in. and draws 11, 12 or 14 W of power from either ac or dc power. Encapsulated, overmold coil construction performs well at high temperatures, is moisture resistant and can be configured in a low-profile option.
Solenoid Solutions Inc., (888) 825-8405, bit.ly/hp113solenoidsol
