Electroproportional cartridge valves combine three functions into one cartridge
Sept. 10, 2013
High-pressure HSPEC multifunction, electroproportional cartridge valve is three valves in one — an electroproportional valve, a post-pressure compensator, and a load-sense shuttle valve.
The high-pressure HSPEC multifunction, electroproportional cartridge valves, with integrated compensators, are rated for 5,075 psi and come in three flow ranges from 9 to 35 gpm. The HSPEC is three valves in one — an electroproportional valve, a post-pressure compensator, and a load-sense shuttle valve. The valves meet NFPA standard T2.6.1 for high duty cycle, high horsepower, and high pressure. The IP69K-rated coils pass the thermal shock dunk test.
Click here to download a PDF product datasheet.
HydraForce, 847.793.2300, www.hydraforce.com
