Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads 2013 03 Comatrol Hsv
High-pressure solenoid valves
March 11, 2013
HSV high-pressure solenoid valves offer high power density and long life. Available in 2-way poppet and spool designs in standard -10 size cavity and -12, -16 and -20 size cavity poppet designs. They are rated for pressures to 350 bar and feature high flow capacities for each size.
HSV high-pressure solenoid valves offer high power density and long life. Available in 2-way poppet and spool designs in standard -10 size cavity and  -12, -16 and -20 size cavity poppet designs. They are rated for pressures to 350 bar and feature high flow capacities for each size. Additional 350-bar rated models, including 3-way and 4-way -10 size solenoid valves and mechanical cartridge valves will be introduced throughout 2013.
Comatrol, Easley, S. C., Member of the Danfoss Group, (864) 644-0055
Click here for more information on this product on the manufacturer's website.
