Joystick pattern changer valve
Aug. 10, 2007
Pattern changer valve provides 8-way, 2-position control of pilot signals. It is designed to be used where switching pilot pressure patterns may be desirable and eliminates equipment downtime, labor, and environmental hazards ...
Pattern changer valve provides 8-way, 2-position control of pilot signals. It is designed to be used where switching pilot pressure patterns may be desirable and eliminates equipment downtime, labor, and environmental hazards involved in switching hoses. Mechanical design makes installation quick and easy while eliminating the possibility of an electronic failure resulting in unwanted behavior.
Holmbury USA, (866) 465-6287, www.holmburyUSA.com
