Flow diverter valves offer flows to 60 gpm and pressures to 5000 psi. Modular design allows up to five additional circuits with minimal pressure drop. Zinc-plated steel bodies and IP69-rated coils withstand severe conditions. They are available as 3- or 6-way single valves; creating up to 14-way flows is optional with modular diverters. Standard ports allow for electric, manual, or pilot pressure operation. Flow diverters can be positioned next to the control cylinders.
