Stackable Hydraulic Directional Valves
Series 21 direct-acting, solenoid-operated valve features O-ring ports to eliminate leakage; enclosed solenoids and connections reduce exposure to elements, and individual load checks are built into each section. Can be combined with series 20 manual valve for increased versatility. Includes 6 gpm nominal capacity, pressure ratings of 4000 psi (272 bar), parallel and 3000 (204 bar), series.
