Eaton
Multi-Function Electrohydraulic Cylinder
March 26, 2018
Eaton’s new offering is a single-source alternative to custom assemblies.
Eaton’s new industrial electrohydraulic cylinder offers a precision feedback transducer and a control valve in one package, making it a single-source alternative to custom assemblies. These cylinders enable reduced setup time due to simplified plumbing and electrical connections. The programmability of the AxisPro valve eliminates repetitive set-ups. Infinite positioning with high repeatability can improve yield in the production cycle, eliminating waste. Programmable motion control enables faster cycles than conventional hydraulic circuitry, enabling higher productivity.
Eaton Corp., (800) 386-1911
