AutomationDirect
Pneumatic Pushbuttons and Pilot Devices
Aug. 29, 2018
ECP series 22mm pneumatic pushbuttons and switch pilot devices are designed for use with pneumatic valve bodies, or users can combine valve bodies and electrica
ECP series 22mm pneumatic pushbuttons and switch pilot devices are designed for use with pneumatic valve bodies, or users can combine valve bodies and electrical contact blocks. Users can also create manual valve assemblies or hybrid electro-pneumatic actuators. Operators allow mounting up to two 3-way valves, or one valve and one to three ECX series electrical contact blocks. The operators fit in a standard 22-mm electrical pushbutton hole. Available pneumatic pushbutton operators include momentary pushbuttons with 30-mm flush and extended round heads, 40- and 60-mm round-head mushroom pushbuttons, key-operated 40-mm round-head mushroom pushbuttons, double-headed green/red rectangular pushbuttons, knob and long lever selector switches, plus 2- and 3-position key selector switches.
AutomationDirect, (800) 633-0405
Carlos Gonzalez | Technical Editor
Carlos M. Gonzalez joined Penton Media Group in 2015. He achieved a B.S. mechanical engineering at Manhattan College and a M.S. in mechanical engineering at Columbia University. Prior to working for Penton Media, Carlos worked at Sikorsky Aircraft in their Hydraulics and Mechanical Flight Controls department; working on their S76D commercial and the Navy’s CH-53K aircraft programs.
