Block manifold system
July 11, 2006
Johnson Block manifold system uses standard blocks that are coupled together to create custom manifolds. Blocks are built from 6061-T6 aluminum and are rated for 3500 psi. Blank modules are stocked for building circuits that can be used with ...
Johnson Block manifold system uses standard blocks that are coupled together to create custom manifolds. Blocks are built from 6061-T6 aluminum and are rated for 3500 psi. Blank modules are stocked for building circuits that can be used with particular valves and suit a variety of flow paths and valve models.
Datum-A-Industries, (800) 806-6162, www.datum-manifolds.com
