Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 06 01 2008 80823 Clippard Ma 00000053170
Pneumatic manifolds
June 10, 2008
Single and multi-station manifolds are available for use with company’s Oxygen Clean series electronic valves. Manifolds offer single- or double-sided mounting in compatible electroless nickel plated brass material, and feature 18-in. NPT input ports and ...
Single and multi-station manifolds are available for use with company’s Oxygen Clean series electronic valves. Manifolds offer single- or double-sided mounting in compatible electroless nickel plated brass material, and feature 18-in. NPT input ports and #10-32 outlets. Available in 1- through 12-stations, manifolds provide easy access for grouping valves, fittings, or other pneumatic components. They are ultrasonically cleaned and inspected in an enclosed controlled area with a High Efficiency Particulate Air (HEPA) filtration system.
Clippard Instrument Laboratory Inc., (888) 256-2178, www.clippard.com/oxygen-h
