Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 9835spotlight02 00000003626
Filter manifold
July 26, 2005
Manifold incorporates return filter head with filter check port, gauge ports for filter and working pressure, manual filter drain, common relief or unloading valve cavity, and auxiliary return port. Expands to accept DO3 single to three station ...
Manifold incorporates return filter head with filter check port, gauge ports for filter and working pressure, manual filter drain, common relief or unloading valve cavity, and auxiliary return port. Expands to accept DO3 single to three station or DO5 single station manifold. Return manifold for use in horizontal or vertical applications. O-ring seals manifold to its mating surface.
Hydro-Craft Inc.
(800) 566-1133
www.hydro-craft.com
