Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads 2013 08 The Lee Co Axial Plug
Manifold sealing plugs
July 11, 2006
Axial Force Only plugs provide leak-tight, metal-to-metal sealing in high-pressure, high-temperature manifold applications. They are removable and reusable and feature a floating seal that self-aligns to allow for threaded holes that are not ...
Axial Force Only plugs provide leak-tight, metal-to-metal sealing in high-pressure, high-temperature manifold applications. They are removable and reusable and feature a floating seal that self-aligns to allow for threaded holes that are not concentric to the thru-hole. They are made of corrosion-resistant stainless steel and seal to 56,000 psi while operating in temperatures to 600° F.
The Lee Co., (860) 399-6281, www.theleeco.com
