Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 09 01 2010 86296 Bosch Hf02 L 00000058920
Valve manifold system
Sept. 13, 2010
Series HF02-LG modular pneumatic valve system with uniform interface features a weight-optimized base plate valve featuring high flow rates of 0.4, 0.7, and 1.4 CV. Modular design enables use of multiple plugs and connections ...
Series HF02-LG modular pneumatic valve system with uniform interface features a weight-optimized base plate valve featuring high flow rates of 0.4, 0.7, and 1.4 CV. Modular design enables use of multiple plugs and connections for all common field buses, with and without I/O signal processing. It provides all valve functions: 2 × 3/2, 5/2, and 5/3. It is designed for an internal working pressure of 36 to 145 psi and can be operated in a temperature range of 32° to 122°F.
Bosch Rexroth Corp., Pneumatics Technology Group, (859) 281-3417, www.boschrexroth-us.com/brp
