Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 12 01 2007 7725649fluidpng 00000049580
Fluid monitoring
Dec. 19, 2007
Fluid monitoring Reservoir-mounted assembly contains level and temperature controls, digital display on same unit as air breather, return filter, and fill and sampling ports. Three sizes — 40, 60, or 100 lpm — fit filter elements and ...
Fluid monitoring
Reservoir-mounted assembly contains level and temperature controls, digital display on same unit as air breather, return filter, and fill and sampling ports. Three sizes — 40, 60, or 100 lpm — fit filter elements and electrical connections. Level and temperature can be monitored by 4-20 mA outputs, multiple switches, or both. Green, yellow, and red LEDs indicate filter’s remaining capacity. Buhler Technologies
LLC, (248) 652-1546, www.buhlertech.com
