Filler breather cap
Aug. 10, 2006
Nylon plastic filler/breather cap interchanges directly with existing die-cast aluminum filler/breather caps. It works with pressure and vacuum applications and features a glass-filled nylon construction and built-in standard lock tab. It is ...
Nylon plastic filler/breather cap interchanges directly with existing die-cast aluminum filler/breather caps. It works with pressure and vacuum applications and features a glass-filled nylon construction and built-in standard lock tab. It is weather, UV, corrosion, and impact resistant.
Zinga Industries Inc., (608) 524-4200, www.zinga.com
How To Select Hydraulic Connectors For Leak-Free Reliability
June 14, 2016
Hydraulic oil leaks are often considered to be an inherent characteristic of hydraulic machines. While this may have been true 30 years ago, advances in sealing technology and...
