Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 10 01 2009 84847 Custommade 00000057166
Custom tanks find favor as hydraulic reservoirs in mobile equipment
Oct. 7, 2009
Custom-made hydraulic reservoirs feature several advantages over their off-the-shelf counterparts. These telehandlers, for example, have a reservoir made to a shape that matches the contemporary design of the rest of the ...
The IFH Group, Rock Falls, Ill., is the largest manufacturer of custom steel fuel and hydraulic oil tanks for off-road and specialty vehicles in the USA. Reservoirs range in capacities from a few pints to more than 300 gal and are manufactured from steel, stainless steel, aluminum, or aluminized steel.
Custom-made hydraulic reservoirs feature several advantages over their off-the-shelf counterparts. These telehandlers, for example, have a reservoir made to a shape that matches the contemporary design of the rest of the machine. Corrosionresistant materials can also be used to maintain hydraulic system cleanliness.
The IFH Group pioneered the use of aluminized steel — a blend of mild sheet steel hot-dip coated on both sides with an aluminum-silicon alloy— to eliminate the contamination problems inherent to uncoated steels. Aluminized steel combines the corrosion resistance of aluminum with the structural strength (and lower cost) of steel. The tanks are resistant to virtually all petroleum-based and synthetic fluids while providing protection from atmospheric corrosion.
Hydraulic reservoirs are built to the needs of the application — everything from a simple two-part tank strap to reservoirs with more than 60 different parts, including level indicators, sight gauges, fittings, filters, strainers, filler-breathers, and any other components required.
Custom-made hydraulic reservoirs have an advantage over off-the-shelf tanks because custom-built units can be designed to fit the exact space and technical requirements necessary for compact design and optimal performance of the end product.
“We provide hydraulic reservoirs and fuel tanks that are installation-ready when they arrive at their dock,” said Jim King Jr., president of The IFH Group. “Our state-of-the-art manufacturing and inventory control systems enable customers to obtain the best product possible and reduce their time and inventory to minimize cost.”
The IFH Group provides on-site design and assembly assistance, as well as standardization of the materials and components required in customer’s reservoirs and tanks to maintain a broad inventory at The IFH Group’s factory, ready for immediate build, quick assembly and fast delivery.
For more information, contact The IFH Group Inc. at (800) 435-7003; e-mail [email protected], or visit www.ifhgroup.com.
How To Select Hydraulic Connectors For Leak-Free Reliability
June 14, 2016
Hydraulic oil leaks are often considered to be an inherent characteristic of hydraulic machines. While this may have been true 30 years ago, advances in sealing technology and...
