Are you (or a kid you know) into Lego?
Feb. 13, 2015
If you're reading this, you're probably interested in hydraulics, pneumatics, or both. And, to quote Bill Cosby, you probably "started out as a child." So assuming you started out life as a child, there's a good chance you spent much of your childhood playing with Lego building blocks. You may have even built some pretty sophisticated pieces.
Click on image for larger view.
But wouldn't it be cool to be a professional Lego model builder? We've probably all seen the incredible structures people have built using Legos. But I found a builder who seems to specialize in building Lego models of heavy equipment that makes extensive use of hydraulics in the real world. But this is Lego World, so the machines use pneumatic rather than hydraulic power.
Check them out by clicking here, and tell me you're not impressed!
Redesigning the Designer’s Role
June 1, 2021
Successful design has historically been the outcome of a trial-and-error approach, but technological advances are changing the rules of the game.
PWM: The Unconventional Way to Regulate Pressure
Dec. 1, 2017
Pulse-width modulation is familiar to those in the electronic control field, but hydraulics engineers probably don’t realize that this technology can be applied to achieve variable...
