Rota Engineering
IFPE Product Innovation: Rota Engineering
March 10, 2020
The firm's new liquid level transducer is an all-in-one solution.
On display at booth S82307, Rota Engineering’s liquid level transducer improves accuracy so operators can better monitor hydraulic tank level and temperature in one sensor. The transducers feature welded, rugged stainless-steel construction with an IP69K high pressure wash down compatible rating.
Rota Engineering designs and manufactures linear transducers for robust applications.
For more information, go to www.rota-eng.com.
