Filter-plug combination
Aug. 10, 2006
FilterPlug incorporates a 40 m inline filter into an air connector for atthe-tool filtration. It lessens contamination, reduces wear, and extends life. It is used on 1/4 or 3/8 in. female-NPT-inlet air tools for industrial, Aro and automotive ...
FilterPlug incorporates a 40 m inline filter into an air connector for atthe-tool filtration. It lessens contamination, reduces wear, and extends life. It is used on 1/4 or 3/8 in. female-NPT-inlet air tools for industrial, Aro and automotive interchanges. Body is case-hardened nickel-plated steel, male NPT threads are nickel-plated brass, and the element itself is sintered bronze. It has a working pressure of 150 psi and a maximum temperature rating of 200° F.
Coilhose Pneumatics, (732) 390.8480, www.coilhose.com
