Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 10 01 2010 86398 Airfilters 00000059063
Air filters
Oct. 13, 2010
Edited By Mary C. Gannon NITRA AF series particulate and moisture separation air filters are available with 1/8 to 1 in. NPT female port sizes and either a semi-automatic or automatic drain. Polycarbonate bowls are standard on 1/8 to 1/2 in. sizes; ...
NITRA AF series particulate and moisture separation air filters are available with 1/8 to 1 in. NPT female port sizes and either a semi-automatic or automatic drain. Polycarbonate bowls are standard on 1/8 to 1/2 in. sizes; 1/4 to 1/2 in. sizes feature metal bowl guards. The 3/4 and 1 in. sizes feature all-metal bowl construction with sight gauges. Replaceable 40 µm filter elements are standard. When stricter filtration is required, optional, user installable, filter elements are available. Mounting bracket for stand-alone applications and modular design enable easy field assembly for combining additional components.
AutomationDirect, (770) 889-2858, www.automationdirect.com/pneumatic-parts
Understanding Filtration Specifications
Nov. 7, 2019
Industry standards for comparing one type of hydraulic filter’s performance to another can seem pretty complicated. Here are some details that might make deciphering some of the...
Tips for Selecting Filters for Pneumatics
Feb. 12, 2020
A clean air supply is vital to equipment running on compressed air.
