Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 05 01 2008 80337airfilterr 00000052792
Air Filter Regulator
May 14, 2008
Type-300 Gulf Buster filter regulator features stainless steel trim and internal construction to stand up to salt water environments. It comes with 14-in. NPT porting. Output ranges include 0-30, 0-60, and 0-100 psig. Maximum supply pressure is ...
environments. It comes with 14-in. NPT porting. Output ranges include 0-30, 0-60, and 0-100 psig. Maximum supply pressure is 250 psig. Standard mounting allows for pipe or through body. Temperature limits range from –20º to 180º F. Flow capacity is 20 scfm at 100 psig supply with 20 psig output. Exhaust capacity is 0.1 scfm with downstream 5 psig above set point.
ControlAir Inc., 603-886-9400, www.controlair.com
