Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads 2012 10 Monnier 201 Air Prep
Pneumatic filters
Oct. 9, 2012
Series 201-7200 and 201-8200 mainline, high-flow particulate and coalescing filters are rated for flows of 400 scfm and 700 scfm, respectively, at 100 psig with a 1.0 psig ∆P. They come in 11⁄4, 11⁄2, and 2 in. NPT, BSPT, and BSPP sizes, as particulate (3 µm element) or coalescing (0.01 µm) styles. They are available with a manual or float drain. Housing is stainless steel.
Series 201-7200 and 201-8200 mainline, high-flow particulate and coalescing filters are rated for flows of 400 scfm and 700 scfm, respectively, at 100 psig with a 1.0 psig ∆P. They come in 11⁄4, 11⁄2, and 2 in. NPT, BSPT, and BSPP sizes, as particulate (3 µm element) or coalescing (0.01 µm) styles. They are available with a manual or float drain. Housing is stainless steel. Monnier Inc., (810) 794-4935, bit.ly/hp1012monnier
How To Select Hydraulic Connectors For Leak-Free Reliability
June 14, 2016
Hydraulic oil leaks are often considered to be an inherent characteristic of hydraulic machines. While this may have been true 30 years ago, advances in sealing technology and...
