Pneumatic in-line filter
May 28, 2013
Clear-VU EZ Connect Filter is an in-line filter for use in most pneumatic, vacuum, and liquid applications. Push-to-connect filter features a clear plastic housing with color coded filter element to indicate micron rating. Push-in connections allow for quick replacement of the disposable filter without having to cut or replace the tubing. They are available in 6-mm and 1⁄4-in.
They are available in 6-mm and 1⁄4-in. sizes, with 10, 48, 65 or 250 μm ratings and a maximum pressure rating of 100 psi.
Industrial Specialties Mfg., (800) 781-8487,
Click here for more information.
