Compressed air filtration
May 28, 2013
Series of Extractor/Dryers is designed to be used as point-of-use filters that efficiently remove moisture and contaminants to improve and extend the life of pneumatic components. Two-stage filter operates most effectively within 25 ft of the point of use. Each model offers a standard 5-μm rating with lower ratings available. They are rated for flows of 15 to 2000 scfm and pressure ratings to 250 psi.
contaminants to improve and extend the life of pneumatic components. Two-stage filter operates most effectively within 25 ft of the point of use. Each model offers a standard 5-μm rating with lower ratings available. They are rated for flows of 15 to 2000 scfm and pressure ratings to 250 psi. Standard features include a built-in differential pressure gauge and weep drain.
La-Man Corp., (800) 348-2463,
Click here for more information.
