Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 13927spotlight0 00000006791
Internal pressure-compensating valves
April 13, 2006
Pressure-compensated proportional flow control valves use a single cartridge and internal compensation spool at full line pressure without need for external compensator. They come in two styles — EPFB priority (bypass) type with bypass port and ...
Pressure-compensated proportional flow control valves use a single cartridge and internal compensation spool at full line pressure without need for external compensator. They come in two styles — EPFB priority (bypass) type with bypass port and EPFI inline (restrictive) type. They feature flows of 3 to 20 gpm and operating pressures of 5000 psi.
Unibody design and oversized seating allow high-torque tightening during installation, reducing need for locking mechanisms or lock wires.
Command Controls Corp., (847) 429-0700, www.commandcontrols.com
