Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 13934products02 00000006797
Air valves
April 13, 2006
VA01 valves for vacuum applications are used in pick-and-place systems. Featuring 5 msec solenoid response time, 10-mm wide valves eliminate two three-way valves when centralized vacuum systems are used with part blow-off. Poppet control ...
VA01 valves for vacuum applications are used in pick-and-place systems. Featuring 5 msec solenoid response time, 10-mm wide valves eliminate two three-way valves when centralized vacuum systems are used with part blow-off. Poppet control valve features a vacuum valve and adjustable blow-off valve with atmospheric-release mechanism that reduces variation of breaking time and overshoots blow-off and cycle time. They can be mounted as a single valve on multiple valve station manifolds.
Parker Hannifin Corp., Pneumatic Div., (269) 629-5000, www.parker.com
