Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 04 01 2008 79792 Ceramicair 00000052273
Ceramic Air Valves
April 16, 2008
Ceram valves use ceramic plates to seal against corrosion, dust, dirt, and sand in air lines. One dynamic and one static plate are made of extremely hard aluminum oxide and are ground. They are available in ISO sizes I to IV, ...
Ceram valves use ceramic plates to seal against corrosion, dust, dirt, and sand in air lines. One dynamic and one static plate are made of extremely hard aluminum oxide and are ground. They are available in ISO sizes I to IV, with flows from 1.1 to 7.5 CV. ISO standard 5599-1 sub-bases feature 14- to 1-in. NPT or ISO G (BSPP) port options. They are rated for working pressure to150 psi (can be externally piloted for low pressure or vacuum applications) and operate with or without line lubrication.
Bosch Rexroth Corp., Pneumatics
(859) 254-8031
www.boschrexroth-us.com
