Latching solenoid valves in 10 and 15 mm sizes are designed for low-power consumption and eliminate need for continuous power to maintain position. Operating pressure is vacuum to 150 psi and works with 12 and 24 Vdc. Internal magnet holds ...
Latching solenoid valves in 10 and 15 mm sizes are designed for low-power consumption and eliminate need for continuous power to maintain position. Operating pressure is vacuum to 150 psi and works with 12 and 24 Vdc. Internal magnet holds activated position when power removed. Single to 12-station manifolds with 10-32 or M5 threads available.
