Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 05 01 2007 66467products03 00000042747
Pneumatic drain valves
May 15, 2007
CRDV/S drain valves eliminate the need for adjustments. They combine an electronic sensor with a solid-state integrated logic analysis circuit to determine exact time required to empty condensate from an air system. Only the necessary amount ...
CRDV/S drain valves eliminate the need for adjustments. They combine an electronic sensor with a solid-state integrated logic analysis circuit to determine exact time required to empty condensate from an air system. Only the necessary amount of compressed air needed is allowed to purge excess fluid, which reduces compressor cycling and wear and tear. They eliminate dirty condensate buildup, thus increasing machine life and reducing rust.
Spartan Scientific, (330) 758-8446, www.spartanscientific.com
