Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 04 01 2008 79783 Proportion 00000052251
Proportional Solenoid Valve
April 16, 2008
PSV-LP single-stage, direct-acting proportional control valve provides a flow rate that is linearly proportional to input current. It achieves 160 slpm with 1 psid across valve with maximum inlet pressure of 2.5 psig and ...
PSV-LP single-stage, direct-acting proportional control valve provides a flow rate that is linearly proportional to input current. It achieves 160 slpm with 1 psid across valve with maximum inlet pressure of 2.5 psig and suits precision control in high-flow/low-pressure applications. Suspended armature eliminates friction and increases repeatability with low hysteresis. Response times are in the 20 msec range from 10% to 90% flow capacity. It is available in 5, 12, or 24 Vdc versions for manifold mounting.
South Bend Controls Inc.
(574) 234-3157
www.sbcontrols.com
